Timing chain
Mike1989
Yeah dude I get that no worries! If it is the chain though and he's right about it being out by that it won't have caused any problems to the pistons etc?
If it damages the pistons you will know about it, don't worry! In the meantime, take it easy on the engine until you get the problem diagnosed! Just out of interest, did it cut out after going through a big puddle and the start up and go in to limp mode? I found out, one rainy and dark night that zeds don't swim too well! :innocent:
No pal was just driving down an a road and it cut out on me! No lights came on until I pulled the airflow sensor out because I thought it was airflow! Then it went into limp mode
So no error codes until you disconnected the AFM?
if cam chain was stretched enough, or the tensioner was dead, for the cam timing to be 10deg out you would definitely be hearing it as mechanical noise,
as said take it to someone who knows the engine.
  • 4 weeks later...
  • 2 months later...
