LED tail lights is not direct fit
cityhunter88
Hi,
Has anyone had this issue.
I have a 2005 GT4, bought i set of facelift LED rear tail lights and its not a direct fit, the connectors won't fit into the LED tail lights.
LED tail light connector,
My standard tail light connector,
Whats my options other than messing around with the wiring.
Thanks.
Yes you need to either trim the connectors above or what I did this time was manage to get the correct connector from a breaker car and remove the connector from the car and repin the correct version on.  Actually quicker to to do than trimming the 3 bits of plastic off each side.
Paul
Paul
Only x1 tab on each plug needs addressing
886749462_1305517224_2005taillightconnector.png.002f2486e1a3393087ffc0cb516871902.png.57b0d1a805dc3af05a1240c2ad4b6c15.png
