Oil Pressure - Max, Zero, Inbetween
buckmoy
Hi all
Just had an oil change/service (main dealer) and a new sump installed (local garage).
54 plate GT with 110k on clock.
Local garage was testing oil pressure with external unit, all good. However they said car's view was it was at zero, and oil light was on. So we installed a new sender, but didn't fix the problem. I let it sit for a few days. Did dashboard dial test, all OK. Started it up and pressure went to max. Then after driving for a bit went to normal, then after about ten mins went to zero. Car isn't losing oil. May be my imagination but it seemed to go to zero under (quite heavy) braking (then not return to normal).
Not expecting a diagnosis, but wondering if anyone has had similar problems?
Thanks
Well. Seems to have resolved itself. Maybe was the new sender getting settled. One day I just started the car and the oil pressure gauge went from zero to a normal cold oil starting pressure (100ish), then immediately down to something too low at idle for cold oil (15 ish), then up to 100 again, then has just been behaving normally.
