Nissan 370z 2008-2011 OEM multimedia satnav system upgrade, Bluetooth audio, newest GPS navi, USB input for Audio & video
Xanavi.net
 Share
This kit is based on the 08IT Clarion hardware, the same system is installed in 2010+ 370z with max. trim level
Possible to do this upgrade on any specs and trim level (if your 370z doesn't have a sat-nav/touchscreen display, you will get it)
Here is the example with Skyline V36 https://youtu.be/UjnjKVcWqIA
What will you get:
️️⚙ The same system as in 370z 2011+ (max. trim level)
️️⚙ Plug&Play installing using the exclusive wiring harness, no need to cut the car's wiring
️️⚙ OEM equipment
️️⚙ Latest map data with Birdview function
️️⚙ Voice guidance
️️⚙ Voice recognition
️️⚙ Using this upgrade we can do the conversion (example: You bought JDM 370z but you live in the UK, after this upgrade you will get the UK specs system)
️️⚙ Available the versions for the USA, Canada, Europe, Australia & New Zealand,
️️⚙ If you have the system w/o satnav and touchscreen, you will get it
️️⚙ USB input for playing audio and video files
️️⚙ Bluetooth Audio
️️⚙ Possibility to connect add-on devices (Android unit, TV box, MirrorLink etc)
️️⚙ Possibility to connect the cameras if your car doesn't have it
️️️️⚙ You don't lose any functionality (BOSE, cameras. etc)
The price depends on your car's config (the lower trim level, more equipment is needed, the price is higher)
To get the price you have to do the next:
PM me here or via the contacts below, send me a photo of your system when it is turned on, provide me with the info on what region version do you need, what is the domestic market of your car (was it imported or not), year of your car
facebook.com/xanavi.net
Instagram.com/xanavi_eng
+37255562274 WhatsApp/Viber/Telegram
xanavi.eng@gmail.com
  • Xanavi.net changed the title to Nissan 370z 2008-2011 OEM multimedia satnav system upgrade, Bluetooth audio, newest GPS navi, USB input for Audio & video
  • 3 months later...
Hi, Looks great.
Mines a 2009GT Ultimate, so Sat Nav bluetooth calls only and no touch screen, do I keep all the functionality of the stock system, so do I see cab temps etc when I turn the heat up and down?
Thanks in anticipation
1 hour ago, Sim said:
Hi, Looks great.
Hi! Yes, it is the OEM Nissan system and ALL the factory functions will work + you will get the new functions ;) We designed the special wiring harness, so you install it w/o the car's wiring cut and if you will sell your car, you can remove it, install the old one and resell our kit :)
I need to update my Satnav from 2011 to 2012. The sat nav cursor is always off map or off route. I dont think Nissan made new maps in the 370 after that. I was told that it needs to be done by the dealer only. Are you guys able to offer an update if i give the current version number?
Ps i didnt have this issue with a 2015 370z but my 2012 has that issue
Sounds like a gps fault not a map one. Roads haven’t moved co ordinates so you will only be off roads that were built post 2011.
I have the connect premium x9.0 Europe v8 full disk set including the software upgrade, try e bay or a Google search for them. You need to provide a code from the head unit to upgrade.
try resetting your location and drive main roads for while first, if it loses its way the the gps antenna or chip.
Possible reasons:
1) head unit fault
2) GPS antenna / wiring fault
3) Any add-on device connected to the system may make some noises for GPS signal
4) Video in motion bypass devices may make noises for GPS signal
5) Imported car made for another region
1 hour ago, GranTurismoEra said:
possibly number 1 or 2. UK car. Its glitched before where the rear video stayed on going forward until I switched it off
+37255562274 Please pm me on WhatsApp/Telegram, will try to help to identificate it and if possible, will help u
4 hours ago, GranTurismoEra said:
Thanks will do. ill do a test drive on Friday to see if its still happening. I reset the navigation settings back to default yesterday. Ive also got my eyes on a gps aerial on ebay.
Please take a video if it will happen again
  • 1 month later...
You can get an aftermarket one much cheaper, I have one you can have/ try if you can cover postage?
as long as it has the correct connection all antenna are basic units, nothing special in a Nissan one.
  • Thanks 1
ill message you in time. Just caught up right now. Ill be at Ace Cafe
 Share
