Right hand drive mid mount single turbo kit 350Z DE
We are proud to introduce you to our Right Hand Drive Mid Mount Single Turbo Kit for Nissan 350Z DE. The only bolt-on kit on the market that is designed for right hand drive 350Z’s!
The turbo is mounted next to the gearbox allowing us to run a 3.5” down pipe which helps minimise back pressure and relief stress from the engine. The engine bay temperatures are also kept  to a minimum.
This kit is capable of producig anywhere from 400whp to 800whp with the right supporting modifications and includes everything you need to turbocharge your 350Z apart from the fuel system and engine management system.
https://www.kudakaperformance.com/product-page/kudaka-performance-right-hand-drive-350z-de-mid-mount-single-turbo-kit
  • Like 2
That fitment looks so neat with good clearance, great that I pairs with the existing y - pipe back. What's now in place to relieve crankcase pressure or is this not an issue due to a low boost setup?
Thank you! We’ve really tried to make this kit as universal as possible but on the same time we’re giving a lot of options for the customers to personalise it.
About the crank case pressure we would recommend a vented to atmosphere system, weather this is a oil catch can or breather filters.That’s probably something to consider adding as an option on the kit.
  • Like 2
 Share
