Centre console help!
terry350z
Hi
I need a bit of help
After taking my centre console apart to get it dipped ,i took apart the flip lid compartment and after putting it back  together it no longer stays open
The 2 springs dont seem to be doing their job
Probably because ive put them back in wrong - i know its an odd one and yes i should have noted how it was when i took it apart
But any help gratefully accepted
Many thanks
Terry
The spring clips should have been under tension when you dissasembled the cubby and therefor should have been under tension when re assembling. They're tricky little buggers and tend to fly off in opposite directions. If this scenario isn't something you experienced then the chances are they're not in correctly.
It's a simple mechanism so it can't really be anything else. Unfortuantely it's a strip down job to correct.
In case you need a bit more info rather than a "Yeah it's wrong" response here's a step by step - https://my350z.com/forum/body-interior-exterior-and-lighting-diy/575663-diy-cubby-door-assembly-springs-pictures-included.html
hi
thank you for the replies to my post
I have sorted it eventually after trying all ways of fitting (about 3 hours)
all sorted now & centre console ,window switches & air vents dipped carbon fibre and refitted
I think its improved my 350  and I love the look and I believe I got this done at a good price
20210123_143015.jpg.76ac5f518c8e10ad3b8387696794f6bc.jpg20210123_143010.jpg.ede0804f50d76dd8560503aa8f8e8911.jpg20210123_143043.jpg.41c7788538c0c72434a3d6bda1486b6a.jpg
On 24/01/2021 at 16:19, hotrain69 said:
Agreed! Looks super smart. I like it!
keen to know rough ballpark of cost too.
On 24/01/2021 at 15:01, Jack94 said:
Looking good B) How much did that set you back if you don't mind me asking?
Hi
it cost me £120 for all items in the 3 pictures that are carbon fibre  which I thought was a pretty decent price
obviously I had to strip down everything so that all he had to do was dip it and it took about 2 weeks turnaround
I had put this off for quite a while because i thought it would be really expensive
I had previously wrapped the switch panels and air vent trims myself which looked ok for a chef but they look much better now and I wasn't going to try and wrap the central console myself
Terry
4 hours ago, terry350z said:
Hi
Terry
Yeah that's a steal... i've seen prices triple that for the same job!
