Invidia Gemini - easy to install?
Mikey_S
Howdy folks
Looking into exhaust options and think I'm likely to press the button on an invidia Gemini system from Torqen.
Running an 06 rev-up, no mods bar a pop charger.
Are these systems easy to install? Could a novice do it after watching a few videos and reading instructions etc?
I don't think I'll go HFC but I imagine many of you would you recommend an up-rev to go with it...
I've browsed the topics and think the system as standard will give me the noise I want.
Also after any other pieces of advice you may have.
If you can get underneath easy enough (can do it with axle stands or ramps at a push) and have a copious amount of Plusgas, breaker bars and possible a dremel handy, then it’s dead easy. Just a few bolts to undo and gaskets to slip in.
  • Thanks 1
The guys at Horsham Developments fitted mine, can't fault their service.
Think they charge £84 to fit a catback system, which in my opinion is an absolute bargain seeing as it saves wrestling with stubborn fixings which haven't been touched in over 10 years.
  • Thanks 1
