Key Fob stopped working! HELP!
smijay
Hi people, 04 UK 350z key fob stopped working this afternoon, have changed the battery and still nothing! Manually locks / unlocks fine via the door slot but alarm goes off until ignition is turned on. Will not lock or unlock remotely (so it can't be the buttons themselves) any common issues or easy / not overly expensive replacement fob options anyone knows of? Thanks in advance!
Edited by smijay
Check the circuit board carefully, sometime the battery contacts are corroded, covered with battery acid or leaked battery acid has short circuited the board. Give it a clean with contact cleaner or scrape it out.
If still not working, buy a used key fob from breaker. Buy a used one, swap the key blade and the immobiliser/transponder chip 'black rectangular carbon looking bit'. Or if yours looks better, just swap the circuit board around. Reprogram it to you zed again and you're done.
https://www.ebay.co.uk/itm/Genuine-Nissan-350Z-Navara-Almera-Micra-Primera-XTrail-2-Button-Remote-Key-Fob/263368279530?hash=item3d51f905ea:g:IVIAAOSwAHtaJyMl
Note: You can only reprogram the unlock/lock function of the key fob yourself on the zed as per instructions link above. The immobiliser can only be done with a device which will cost you £100 to £200 each time.
  • Thanks 1
