Passenger door unlock
Initial_j
35 minutes ago, Jack94 said:
I'm sure somewhere in the owners manual there's a way to change it between 1 or 2 stage unlocking using the fob..
Only on later cars, I don’t recall when it changed though. Toggled simply by holding the button for several seconds, iirc.
On 05/07/2018 at 18:24, mr v6 said:
This also works for my 05, but I left it so the passenger door stays locked.
I also have a 05 . But no keyfob..
Got buttons on my keys... how did you change it?
Hold both buttons down for a few seconds, then unlock the car with the remote key, if you've done it right both doors will unlock. If you want to revert back to only the drivers door unlocking, just repeat the procedure.
  • Thanks 1
