Oil capacity
leeroy73
The car doesn't loose oil or smoke and I've never had a dash oil light on.. I actually didn't check the oil prior to doing the change. But car was at operating temp before I drained it but only 1 3/4 litres came out! Have put just under 5 litres in and will check level later once cooled but what I have noticed is the oil pressure gauge doesn't read like it did. Before it you to sit just around 4 and then go up when I put my foot down but now its between 0 And 4 at idle and creeps above 4 when I accelerate.
I appreciate all your replies :) hands covered in much atm so hard to reply straight away :)
Sent from my HTC One using Tapatalk
